Forums >> Revit Building >> Technical Support >> Floor at different level
Thu, Jan 5, 2012 at 11:27:10 AM | Floor at different level
renatolemus
Hi everybody!, I want to create 2 tiled floors at different levesl, as shown in the picture. Do I need to create another level for this lower floor, or should I separate the 2  floors. I'd appreciate if someone could suggest a workflow for this, in such way that revit can "understand" for generating accurate sections and schedules.
thanks in advance
Thu, Jan 5, 2012 at 11:44:08 AM | Floor at different level
This is really your option.
If you make it all one level, I would choose the lower as my base with the raised floor defined as such.  This allows all rooms / walls / other items to be defined as being on the same level.  Just remember to raise the doors and other level hosted elements in the raised area.
Thu, Jan 5, 2012 at 11:58:52 AM | Floor at different level
coreed
coreed Avatar
4 Stars: 16 Votes
if you want it to schedule as one level. then i would follow WWHub advise.
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Thu, Jan 5, 2012 at 7:04:39 PM | Floor at different level
renatolemus
thanks for your help.
Site Elevation to Floor Level Problem
Wed, Jun 27, 2012 at 11:42:30 AM
I made a Level without a floor plan... but now I want one.
Fri, Dec 5, 2014 at 4:47:53 PM
Floor Plan associated to wrong level...
Fri, Jul 2, 2021 at 3:23:05 PM
Elevation Level Marker Associated To Wrong Floor Plan
Wed, Feb 25, 2015 at 10:44:23 AM
Revit Arch 2013 - Roof - Starts at first floor level and second floor level
Mon, Sep 10, 2012 at 8:11:53 AM
Page generation time: 0.4036
