Forums >> Revit Building >> Technical Support >> widow head and sill sweeps
Sun, Dec 11, 2005 at 5:17:18 PM | widow head and sill sweeps
tekeda1
I created 2 sweep profiles for a stone window lintel and sill. When I add the sweep to my model it runs the entire length of the wall it is added to. I can then stretch it so that it is just the lenght of the window. But when I copy this sweep to the another window, the sweep changes size to the lenght of the entire wall. Is there any way to easily copy these head and sill sweeps to other windows? Or does anyone have any idea how to creat a parametric window assembly that would use a curtian wall system with automatic head and sills Thanks, Tim Mailloux
Sun, Dec 11, 2005 at 5:46:13 PM | RE: widow head and sill sweeps
eldados
eldados Avatar
4.5 Stars: 8 Votes
the sweep is hosted by the wall, that's why it's spanning the length of the wall, though it should paste to another wall with the length you gave it... you can easily add your lintel to the window family (normal windows) with curtail walls, you can create a new mullion, the size and material you need and insert it as the top mullion, you can add the normal window mullion just under it... HTH
Integrator
KarelCAD
Window Schedule - Head/Jamb/Sill References
Wed, Jul 15, 2009 at 3:30:02 PM
Setting Window Head Height
Fri, Feb 24, 2017 at 12:16:49 AM
14
head height of window
Thu, Nov 3, 2005 at 5:19:14 PM
Window Schedule - Jamb, Head, Sill
Wed, Aug 7, 2013 at 4:06:57 PM
14
Sill and head height of windows - in the dimension I can only show the actual
Sun, Aug 18, 2024 at 1:01:15 AM
Page generation time: 0.4401
