Forums >> Revit Structure >> Technical Support >> Tagging objects within an assembly?
Tue, Jan 3, 2012 at 4:27:04 AM | Tagging objects within an assembly?
WiRoAn
Im wondering if anyone has been able to do this or if you are limited to tag the Assemby itself?
For example.. if I have a concrete column with rebars and I make an assembly from this. Is there any way to go to the assembly views and tag the corresponding rebars?
It would work wonders if its possible since I have the need to make shop drawings for these.
At the moment I need to make sections and elevations for this which is automatically done with the Assembly-command.
Tue, Jan 3, 2012 at 3:08:47 PM | Tagging objects within an assembly?
Eddieboarder91
Eddieboarder91 Avatar
4 Stars: 8 Votes
I know with component families you can set a nested family to be shared and that way you will be able to tag the sub-
components though I am not sure if that would work the same with columns.
www.allbimallthetime.blogspot.com
http://familyjewels.typepad.com/
assembly
Mon, Apr 22, 2013 at 5:03:46 AM
Modifying vertical structure in edit assembly
Fri, Feb 9, 2018 at 4:27:20 PM
Tagging assemblies, and appearance in schedules
Fri, Aug 4, 2017 at 10:32:04 AM
Uniformat assembly codes
Thu, Jan 31, 2013 at 11:21:11 AM
Existing wall assembly visable in New Construction phase
Wed, Nov 2, 2011 at 5:49:09 PM
Page generation time: 1.7138
