11 Users Online (9 Members):
Forums >> Revit Building >> Technical Support >> Manipulating the Leader Line
10 Posts No Rating |
Hope everyone had a great holiday and are off to a great New Year. I have an issue with a wall tag that I created. There is a box tilted 45 degrees with a note inside and a secondary note outside the box in a circle. My problem is that the leader line does not attch at the corners of the box, rather it seems hit at the center line of the overall geometry. So it doesn't attach to the tag directly. Is there a way to control where the leader lines eminates from?
I have attched the tag for clarity.
As far as I can tell, no.
Dang, I was affraid of that being the case. Thanks for your help. How can I suggest that for an option of the next version?
There is a wishlist forum here. You might want to check if there is an existing post, if there is just bump that.
Adding Snaps to Leader Lines |
Thu, May 29, 2014 at 7:34:34 AM
Callout Leader Line Straightening After Placing |
Fri, Jan 22, 2016 at 3:36:22 PM
leader note line |
Wed, Aug 22, 2012 at 2:18:01 PM
Leader Line Line weights |
Sat, Feb 7, 2009 at 10:47:57 AM
Positioning the leader on a tag. |
Thu, Aug 6, 2015 at 12:16:39 PM
