Forums >> Revit Building >> Technical Support >> Inter connecting REVIT LINKS
Wed, Dec 28, 2011 at 3:24:09 AM | Inter connecting REVIT LINKS
renjith
working in Plumbing drawings, in muti-storey residencial building with typical floors. Created one typical floor Plumbing revit drawing and linked that revit file to each floors which are typical. Now I want to connect that revit links to vertical risers/downcomer. I connected this revit links While converted to revit group. But that also not resolves the issue. While connecting, the part of the pipe is ungrouped. Please help me out from the issue.
Wed, Dec 28, 2011 at 8:10:23 AM | Inter connecting REVIT LINKS
Why didn't you simply copy those elements to seperate floors withing the project?  Select all the elements and paste them aligned to selected levels.
Mon, Feb 20, 2012 at 3:22:55 AM | Inter connecting REVIT LINKS
renjith
In case of archi. changes, I have to change all the floors with respect to changes. If revit link inter connection is possible, I can change at a time with revising that link.
*URGENT * - Worksets & Links
Mon, Oct 12, 2009 at 5:51:32 PM
Connecting Stairs to top level
Fri, Jan 20, 2012 at 2:20:09 PM
13
Trouble converting links to groups
Tue, Oct 25, 2016 at 12:12:21 AM
Baluster not connecting to rail
Wed, Nov 30, 2011 at 5:32:02 PM
13
connecting gutters
Thu, Sep 12, 2013 at 2:45:24 PM
Page generation time: 2.9925
