Forums >> Revit Structure >> Technical Support >> Nested Links Warning
Tue, Dec 27, 2011 at 2:49:07 PM | Nested Links Warning
bizz3d
Is there a way to turn off this warning? I have an Arch. model with many linked files some overlay some not. I get a warning every time i open the file. its 5 files and copied throughout the building. so for every instance i get about 50 warnings, every time i open it.
Wed, Dec 28, 2011 at 7:12:00 AM | Nested Links Warning
Wow... are these linked CAD files?  If so, then this is a bad practice - I know - not your fault.
I probably would just put dummy files in my directory.
If the architect would set these links to Overlay, they should not load into your model.
Edited on: Wed, Dec 28, 2011 at 8:03:50 AM
Dimensioning to CAD links in Revit - Dims deleted
Wed, Aug 7, 2013 at 2:39:01 PM
Save to Central Warning?
Wed, Jun 17, 2009 at 11:17:25 AM
Visibility in Nested (Attached) Linked Models
Mon, Nov 4, 2013 at 2:44:29 AM
How to disble annoying Warning
Fri, Feb 9, 2007 at 7:09:03 PM
Trouble converting links to groups
Tue, Oct 25, 2016 at 12:12:21 AM
Page generation time: 0.1011
