14 Users Online (12 Members):
Forums >> Revit Building >> Technical Support >> Coarse, Medium, and Fine Settings
20 Posts No Rating |
I am using Revit 2012. I would like to able to set certain lines to show up in different detail level view settings. More specifically, I would like certain material lines within my walls to show up in section, but not in plan. I thought the best way to do this was by changing the view settings from fine to medium; however, I have not found a way to assign specific lines to show up in fine and not medium. Is it even possible to assign specific lines to a detail level view?
Thanks
Have you tried view templates? You can create your prefered view setting when you make a new view or apply it to an existing view. There you can set up fine or medium and adjust your graphic scale options.
Motto: "No Post left behind" |
Visibility control of wall layer lines is very limited. Your coarse / medium-fine switch is by category, not wall type. Other than that, you could use a filter to change the linework settings for some of your wall lines but you can't turn them off.
Okay. Thanks for your help!
Different colors in Coarse/Medium/Fine? |
Mon, Sep 13, 2010 at 9:28:50 AM
Walls – Coarse, Medium and Fine or... |
Thu, Oct 8, 2009 at 3:19:49 PM
sloping roof joists only displays on medium/fine |
Tue, Mar 31, 2009 at 1:33:01 PM
Fine, medium, course view option not available! |
Mon, Mar 10, 2014 at 9:52:32 AM
Visibility Settings - Scale |
Mon, Jun 21, 2010 at 5:33:55 PM
