12 Users Online (11 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Structure >> Technical Support >> Wall based embedded plate family not showing up hidden.....any thoughts why not?
Tue, Dec 27, 2011 at 8:21:20 AM | Wall based embedded plate family not showing up hidden.....any thoughts why not?
structuresguy
I have created a wall based model family of a steel plate, to represent embedded plates in tilt-up walls.  Everything works fine except the plates do not show up hidden in an elevation view of the wall, when they are on the opposite face.  Beams and intersecting walls on the back side show up hidden, and on course anything on the front side shows up solid.  But the plates simply do not show up at all.  Now, I can use the "display hidden lines" tool to get them to show up, but this is time consuming and I run the chance of missing something.  I just don't understand why one object shows up hidden but not others.  Does anyone know of a way to get these to show up hidden by default?  I have tried both wall based and face based, and neither worked.
Thanks much.
Tue, Dec 27, 2011 at 9:06:28 AM | Wall based embedded plate family not showing up hidden.....any thoughts why not?
How about placing those hidden lines in the family on the otherside of the wall.
Tue, Dec 27, 2011 at 1:01:00 PM | Wall based embedded plate family not showing up hidden.....any thoughts why not?
structuresguy
Good idea, that could work.  But I have actually changed it to a Face based family now, so that I can add it to any object, walls, columns, beams, etc....  I don't think I could do the same with Face based, not sure?  I'll look into it.
Thanks.
Sill plate?
Thu, Jan 28, 2010 at 5:10:16 PM
changing type of a family from wall based to face based
Wed, Mar 3, 2010 at 8:24:37 PM
Structural Connection Family [ 1 2 ]
Tue, Jul 28, 2015 at 5:08:43 AM
19
Is it possible to make a line-based family wall based?
Wed, Jan 5, 2011 at 1:00:21 PM
Revit 2013 family from wall based to flor based
Mon, Feb 4, 2013 at 6:56:51 AM
Page generation time: 2.1428
