Forums >> Revit Building >> Technical Support >> Annotation parameter moving wrong line
Wed, Dec 21, 2011 at 9:10:02 AM | Annotation parameter moving wrong line
archie456
3 Stars: 1 Votes
Hi,
I feel like this is a stupid question, but I can't seem to figure out the answer.
I've created a titleblock annotation family, and want to have a box with some text in it that the user can reposition on the sheet.
I've created the box as an generic annotation and have loaded it into the titleblock family, and created two parameters for the verical position and horizontal position the parameters are dimensions between the titleblock boarder to the edge of the text box.
The problem is that when I flex the family, it moves the boarder and not the text box.
What am I doing wrong??
Cheers.
Wed, Dec 21, 2011 at 10:50:07 AM | Annotation parameter moving wrong line
Did you try pinning the border lines first?
Wed, Dec 21, 2011 at 10:55:56 AM | Annotation parameter moving wrong line
archie456
3 Stars: 1 Votes
yes tried pinning them - they still moved.
Wed, Dec 21, 2011 at 12:20:43 PM | Annotation parameter moving wrong line
Then I suggest you add a reference line, pin it and then add your constraints to that.
Thu, Dec 22, 2011 at 2:47:42 AM | Annotation parameter moving wrong line
archie456
3 Stars: 1 Votes
That worked! Thanks.
Moving Annotation Symbols without moving objects
Mon, May 23, 2011 at 6:39:43 PM
Nested annotation labelt o report a family parameter?
Tue, Oct 15, 2013 at 4:05:27 PM
Add angle parameter to generic annotation with offset parameter
Mon, Mar 2, 2020 at 12:57:06 AM
Generic Annotation with Family Category based parameter
Mon, Sep 16, 2013 at 7:18:15 PM
Changing rotation of annotation on electrical symbols
Wed, Feb 11, 2015 at 9:11:49 AM
Page generation time: 1.0117
