Forums >> Revit Building >> Tips & Tricks >> Acoustical Ceilings
Wed, Dec 21, 2011 at 8:58:50 AM | Acoustical Ceilings
cpatton
I need to create an acoustical ceiling in Revit that imports to Navisworks so that the panels and the metal framing system are seperate entities.  I need to be able to turn off or delete the "panels" in Navisworks so that all that is visible is the framing system.  Default acoustical ceilings in Revit import to Navisworks as a solid ceiling system as if it was gyp board with a grid hatch on it.
Does anyone have any tips on how to create this?
Mon, Dec 26, 2011 at 9:52:06 AM | Acoustical Ceilings
You will not be able to do this with a normal ceiling.  You could use a ceiling with a framing system applied to it.  I probably would create a grid family with a void mask to cut it to shape.
Tue, Dec 27, 2011 at 9:19:15 AM | Acoustical Ceilings
coreed
coreed Avatar
4 Stars: 16 Votes
Also you could create your ceiling as an in-place generic model mass. then apply a curtain system and mullions. turn off the mass and panels and you have your metal framing system.
Edited on: Tue, Dec 27, 2011 at 9:34:14 AM
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Missing compound acoustical ceiling in 2015
Mon, Apr 13, 2015 at 7:34:34 AM
Complex ceilings
Thu, Oct 8, 2015 at 1:02:54 PM
Vector Printing - Ceilings Disappear
Wed, May 28, 2014 at 9:12:41 AM
Sloped Ceilings
Thu, Jan 23, 2014 at 4:54:40 PM
14
Model In Place Ceilings Not Scheduling??
Wed, Jan 15, 2014 at 10:55:35 AM
Page generation time: 0.3934
