21 Users Online (19 Members):
Forums >> Revit Systems >> Technical Support >> Solid Works to Revit
2 Posts No Rating |
I have dental chairs and units in solid works I am trying to get into Revit. I've tried SolidWorks save file to step AP214, open in Inventor Fusion, save to SAT and open in Revit. No great success. Miscolanious things dissapear and you can not add materials to render. turns into grey lumps. Trying to rebuild the units in Revit but as a moddeling software Revit is not working. Complex forms are not working.
Any ideas how I can get this to work with rendering and no holes everywhere?
have you tried, sketchup. then import them into a family, then import to revit.
2 Posts No Rating |
I haven't used Sketch up before and was trying to get this done without have to learn another software. Is sketch up good for complex forms?
I believe you can save your solid works files to something that can be read in Sketchup, then you can save them in a format, that can be read by Revit. And yes sketch up is pretty good with unusual forms, also check out 3D warehouse. Some manufacturer's are using sketchup for there 3D modeling for use in Revit and other 3D programs.
Edited on: Wed, Dec 21, 2011 at 11:03:20 AM
create floor or other solid mass from Topo |
Wed, Oct 2, 2013 at 9:29:26 PM
Solid Drafting fill pattern |
Tue, Jun 23, 2015 at 1:35:01 PM
X, Y, Z SOLID EXTRUSION |
Wed, Jan 5, 2011 at 12:02:16 PM
Revit and solid state hard drives |
Mon, Feb 2, 2009 at 9:31:28 AM
Solid Sweep Not Cutting in Section |
Mon, Dec 18, 2006 at 2:06:34 PM
