Forums >> Revit Building >> Technical Support >> rendering light source
Mon, Dec 19, 2011 at 3:21:42 PM | rendering light source
Ptrdckrsn
Ptrdckrsn Avatar
1 Stars: 1 Votes
I have a simple renderng and cant get the light source to apper in the rendereing.  i have the light sources turned on and i know they are  there but when it renders no lihgts are on.  i have them checked in the artificial light source and set to artifcial only. any ideas what i am missing.  I have done other renderings and other lighgts work. but with this one no lights are on.
Mon, Dec 19, 2011 at 3:31:30 PM | rendering light source
If you read the similar threads below, you will find that there are usually two possible problems.
  1. If you light is recessed, does the family cut the ceiling?
  2. Does your light actually have a light source in the family?
Mon, Dec 19, 2011 at 3:50:41 PM | rendering light source
Ptrdckrsn
Ptrdckrsn Avatar
1 Stars: 1 Votes
yes i have the light source turned on in VV.  It is shinning on the ceiling that's how i know it is there. problem is it worked this morning but now it doesnt want to play fair. Not sure what i did between this morning and about 2 hours ago.
Light source inside the light fixture
Fri, Feb 22, 2013 at 7:24:32 AM
Light Source in Revit - the dead horse
Thu, May 6, 2021 at 4:34:17 PM
13
Light Source not rendering.
Fri, Mar 17, 2017 at 11:09:15 AM
Light Source
Thu, Feb 19, 2009 at 8:01:01 AM
Downlight with hidden light source
Sat, Nov 23, 2013 at 8:19:33 AM
Page generation time: 2.8372
