Forums >> Revit Structure >> Technical Support >> Footings, getting double hidden lines and intersections suck!
Sat, Dec 17, 2011 at 7:19:45 PM | Footings, getting double hidden lines and intersections suck!
ljshoreslokal
Vent first, I hate the fact that Revit is a program that is not at all user friendly and tries poorly to do the thinking for us. Ttying to lean a new program can be a task already but having to trick this POS all the time into making things work is a eating at me.
My problem.
First, my L shaped footings are coming up with double hidden lines on each side that end up looking like a solid line most of the time.
Second, the footing intersections with other footings and pad footings are not clean. How do i make the intersecting lines disappear?
Thanks in advance!!
Mon, Dec 19, 2011 at 3:08:16 PM | Footings, getting double hidden lines and intersections suck!
mhans
3 Stars: 10 Votes
Can you post a screenshot? Check the drawing scale and detail level. For footings to clean up automatically, they have to be placed on the same level.
Motto: "No Post left behind"
Thu, Dec 22, 2011 at 7:57:05 AM | Footings, getting double hidden lines and intersections suck!
jprajzner
I have the same problem with double hidden lines looking like solid lines.  This tends to happen when footings intersect with different thicknesses.
Thu, Dec 22, 2011 at 8:09:28 AM | Footings, getting double hidden lines and intersections suck!
jprajzner
Sorry trying to attach a screen shot.  My jpeg will not load
Edited on: Thu, Dec 22, 2011 at 8:20:11 AM
Fri, Aug 31, 2012 at 10:13:08 AM | Footings, getting double hidden lines and intersections suck!
deniko68
In the VG under Structural Foundations uncheck 'hidden'. See if this will work for you
"Double" lines in view range beyond
Fri, May 17, 2019 at 12:34:14 PM
Show Hidden Lines Creating Double Lines
Mon, Sep 23, 2013 at 11:55:16 AM
hidden line view intersections
Mon, Nov 8, 2004 at 7:58:14 PM
hidden lines below grade
Mon, Oct 1, 2007 at 2:19:41 PM
Beam/Beam Intersections of Multiple Depths - Hidden lines?
Fri, Mar 23, 2007 at 1:23:59 PM
Page generation time: 1.2916
