Forums >> Revit Building >> Technical Support >> Hatch Pattern
Fri, Dec 16, 2011 at 10:54:26 AM | Hatch Pattern
art1013
I am having trouble drawing a new hatch. I need to create a new pattern that consists of irregular size rectangles. It is basically made up of a series of repeating rows. It starts with a 60x15cms rectangle, followed by a 40 x15 cm rectangle and then a 20x15cm rectangle. On the second row, this pattern will mirror itself starting with the 20x15 cms rectangle. The starting point reference will be 20 cms to the right after the starting point of the 60x15 at the first row (both of this rectangle centers line up horizontally). This line continues with the 40x15 followed by the 60x15. I’ve attached a CAD file with the pattern and its dimensions for better understanding. Could somebody please help me? Thanks.
Sat, Dec 17, 2011 at 1:19:35 AM | Hatch Pattern
hugh
3.5 Stars: 4 Votes
Revit wants millimetres for a metric pattern so a reasonably compact definition is ...
;%VERSION=3.0
;%UNITS=MM
*PATTERN
;%TYPE=MODEL
;        Pattern written by HatchKit v2.7 Hatch Pattern Editor
;        HatchKit v2.7 Hatch Pattern Editor(c) Cadro Pty Ltd 1990-2011.
;        www.hatchkit.com.au
0,0,150,0,300
0,0,0,0,300
-90,600,150,0,1200,150,-150
-90,400,300,0,1200,150,-150
-90,1000,300,0,1200,150,-150
-90,0,150,0,1200,150,-150
-90,800,300,0,1200,150,-150
-90,200,150,0,1200,150,-150
hth
Hugh
Hugh Adamson
www.hatchkit.com.au
Mon, Dec 19, 2011 at 6:17:20 PM | Hatch Pattern
art1013
Thank you so very much!! Really nice of you... You saved us a lot of work! Thanks again!
Mon, Dec 19, 2011 at 8:41:15 PM | Hatch Pattern
hugh
3.5 Stars: 4 Votes
No worries, a DXF from the DWG was easy to cut down to the essentials manually.
We also benefit because that pattern showed up an edge case in testing a new feature.
Win-win Smile
Hugh Adamson
www.hatchkit.com.au
Exporting hatch pattern
Thu, Sep 18, 2014 at 6:27:35 PM
hatch pattern not printing
Mon, May 8, 2017 at 12:56:51 PM
Hatch pattern
Tue, Jan 13, 2009 at 10:23:47 AM
Hatch 22- Curve Pattern
Wed, May 30, 2018 at 4:07:07 PM
custom hatch pattern without hatch editor
Wed, Jan 28, 2015 at 8:46:58 PM
Page generation time: 0.1233
