Forums >> Revit Building >> Technical Support >> Revision date and number
Fri, Dec 9, 2005 at 2:05:04 AM | Revision date and number
jyothi
How do we get revision date and number and the sheet number which was revised in the drawing list.i want in my cover page to display when the sheets was revised and which sheet was revised. i created a parameter but did not work the way i want. can any one suggest me regarding this. Thanks, Best regards
Fri, Dec 9, 2005 at 2:30:07 AM | RE: Revision date and number
eldados
eldados Avatar
4.5 Stars: 8 Votes
go to your title block sheet go -->view-->new-->revision schedule Revit will create a revision schedule, drag it into your title block and load it into your project. in your project go to setting--> revisions in the dialog box that opens define your revisions with date and number. draw a revision cloud, click on ii and go to properties, define the number of this revision cloud. HTH
Integrator
KarelCAD
Fri, Dec 9, 2005 at 3:06:35 AM | RE: Revision date and number
jyothi
Thanks, But when i went to--view--- new--- revision schedule is grayed off how do i activate that. Do i have to manually enter date and number some where does revit update it automatically? Best regards
Sun, Dec 11, 2005 at 5:30:57 PM | RE: Revision date and number
eldados
eldados Avatar
4.5 Stars: 8 Votes
you will need to open your title block drawings, there you can insert a revision schedule. once you load it into your project, you can control the revision through setting-->revisions.
Integrator
KarelCAD
Mon, Dec 12, 2005 at 7:28:00 AM | RE: Revision date and number
jyothi
Thanks a lott for your help.it worked out fine. Best regards,
Mon, Dec 12, 2005 at 11:27:01 AM | RE: Revision date and number
trich00
I would like the revision date and name to show in the sheet index on the cover sheet too - which I thought was the original question. I have the revsion schedule in our title block but those parameters for the revision schedule I cannot get on my sheet index. The explination you gave appears to be how to get the revision schedue on each sheet. Is there a way to get the revsion inforamtion to show up on the sheet index?
Tue, Dec 23, 2008 at 12:59:06 PM | Revision Tag and Revision Issue Date on Sheet Index
arlettemp
I have been trying to do this for sometime now.  Does anyone know how I can place a revision tag and revision issue date on my sheet index.  I've tried all kinds of parameters, but nothing is working.  Please help!   Revision tag and revision Issue Date on Sheet Index not Titleblock.
Mon, Dec 29, 2008 at 3:22:17 PM | Revision date and number
tim1424
i cannot figure this out either!  there must be a way for the sheet index schedule to read what the issue date and revision date are!
Mon, Dec 29, 2008 at 4:59:58 PM | Revision date and number
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Without checking in Revit, but assuming you guys have tried creating a Drawing list and the revision parameters are not available to add to the drawing list schedule...
Then you will not be able to achieve this using the revision schedule tool.
You would need to manually add shared parameters to the titleblock for the revision parameters and then add those to your schedule.  This essentially kills all the smarts to the revisioning system.  This was the way we used to do things before they fixed the revision tool to allow more display flexibility...
Regards,
Chris.
Current Revision Date in sheet index
Mon, Nov 2, 2009 at 11:22:28 AM
Date & Created By in a family similar to revision cloud.
Mon, Jun 16, 2008 at 11:13:28 AM
Revision editing
Wed, Sep 3, 2014 at 3:31:46 AM
Revision Number for sheet issued for the first time [ 1 2 ]
Tue, Oct 15, 2013 at 10:05:01 AM
19
Duplicate Revision Tags
Thu, Dec 4, 2008 at 4:45:56 PM
Page generation time: 0.2617
