15 Users Online (13 Members):
Forums >> Revit Building >> Technical Support >> Different Lineweights for Different Types of Walls
19 Posts No Rating |
Hello! I am in the process of setting up lineweights in our company template. I am curious to know if there is a way I can change the lineweight of the wall depending on the type of wall it is. For example, is it possible to make bathroom stall walls or soffit walls a different cut lineweight than exterior walls? They are showing up too think in my plans and sections when all of the other walls are looking good. I know in object styles it only gives the option of changing the "Wall" lineweights but I am hoping there is a way around this. Thanks!
If your interior walls were on a different workset, you could set up a filter to change these lines but it miay not do exactly what you want.
- VG for the view
- Filter tab / add new
- Pick walls
- Then filter by workset
- add that filter
- change the vg cut lines....
You can also use a variaty of other type parameters to filer by. We use 'Function' alot for interior vs exterior walls. You may want to try and use type comments = Stall etc..... And you can add these to your template and in turn view templates.
Filtering is probably the only way to get close to what you want.
Luke
Lineweights in REVIT |
Wed, Oct 1, 2008 at 1:39:01 PM
Lineweights Issue |
Thu, Nov 17, 2005 at 6:05:35 PM
Lineweights Question |
Wed, Aug 3, 2005 at 4:03:11 PM
Revit lineweights |
Wed, Jan 28, 2015 at 9:31:49 AM
Lineweights By Phase |
Thu, Nov 8, 2007 at 10:11:15 PM
