18 Users Online (16 Members):
Forums >> Revit Building >> Technical Support >> SHEETS
41 Posts No Rating |
Revit 2011. When I populate a sheet with a drawing, I get the drawing plus a long line with the scale and the name of the drawing. This is great except that sometimes the line extends past the edge of the sheet. I can move the line but am unable to reduce the length. What's up?
Carl
If you are using the stock view title, the line matches the length of your view window initially. While on the sheet, click on the view and you will see a blue dot on the line - now drag that back.
Reordering Sheets |
Thu, Nov 1, 2018 at 2:09:29 PM
Sheet Number Already in Use...I have ghost sheets. |
Tue, Nov 21, 2017 at 8:47:10 PM
Linked Revit Model Sheets |
Fri, Apr 5, 2013 at 12:04:28 PM
CONTROLLING THE ORDER IN WHICH SHEETS ARE PRINTED |
Tue, Aug 5, 2008 at 1:18:31 PM
Sheets in families? |
Thu, Mar 27, 2008 at 1:03:09 PM
