Forums >> Revit Building >> Technical Support >> Plot Order
Tue, Dec 13, 2011 at 7:41:44 AM | Plot Order
cboersen
Is there a way to change the plot order of the sheets within Revit 2011?  I need to plot my sheets in an order that is not alpha-numeric.  How do I change the plot order like you can within AutoCAD publish?  I have been plotting to a PDF and then changing the order there but it is cumbersome.
Mon, Jan 2, 2012 at 2:05:33 PM | Plot Order
e00878
If you have Autodesk subscription you can use Batch plot utility for Revit.
http://wikihelp.autodesk.com/Revit/enu/2012/Help/Add_Ins/0000-Batch_Pr0/0001-Using_Ba1
then you can adjust plot order.
http://www.get-rfa.com
FREE REVIT RFA DOWNLOADS
Tue, Jan 3, 2012 at 6:43:19 AM | Plot Order
cboersen
Your right, batch plot can do that. However, batch plot cannot save that order so each time it has to be redone and batch plot cannot plot to a PDF. As far as I am concerned batch plot is worthless unless you know something I don't. Honestly, how hard can it be to have something that AutoCAD has had for a long time. Thanks.
Tue, Jan 3, 2012 at 7:53:35 AM | Plot Order
e00878
Now I using batch plot for printing to PDF files.
PDFcreator adjusted to autosave is helping me Smile
http://www.revitwatch.com
Tue, Jan 3, 2012 at 9:40:18 AM | Plot Order
cboersen
We have Adobe and I set that to autosave but it crashes batch plot every time.
draw order
Wed, Aug 20, 2008 at 8:26:33 AM
Plot Preview in PDF
Wed, Feb 22, 2012 at 11:28:24 AM
Plot log
Thu, Feb 5, 2015 at 8:06:04 AM
raster image will not plot
Thu, Sep 24, 2009 at 8:43:42 AM
Single sheet PDF Naming error
Tue, Nov 23, 2010 at 7:18:24 AM
Page generation time: 0.5959
