Forums >> Revit Building >> Technical Support >> Can't relocate viewport with move command
Mon, Dec 12, 2011 at 5:11:40 PM | Can't relocate viewport with move command
stealthnyc
4.5 Stars: 2 Votes
I'm using Revit 2012 and when I try to use the move command to relocate a viewport I get the following error: "Selection cannot be copied.  Multiple instances of the same view in sheets not supported."  I don't understand this because i'm using the move command, not the copy command.  Any help is appreciated.  Thanks.
Mon, Dec 12, 2011 at 5:14:11 PM | Can't relocate viewport with move command
stealthnyc
4.5 Stars: 2 Votes
Nevermind.  I restarted Revit and it works as expected..
Project relocate command
Thu, Jun 24, 2010 at 7:41:56 AM
Draw Order of Viewport on a sheet
Wed, Dec 16, 2009 at 4:35:58 PM
Viewport title locked. How to unlock?
Tue, Sep 30, 2008 at 3:20:48 PM
Align Floors on Multiple sheets
Thu, Aug 24, 2006 at 6:02:33 PM
Revit 2016 pauses to update during move command
Wed, Mar 2, 2016 at 9:05:21 AM
Page generation time: 0.4483
