Forums >> Revit Building >> Technical Support >> Linked model overwriting base model display in sections
Mon, Dec 12, 2011 at 5:35:20 AM | Linked model overwriting base model display in sections
Cotapaxi
Morning all,
I have an Architectural Base model to which I have attached a Structural model which displays correctly in 3d, plan & elevation, however; when I cut a section the structural model overwrites the display of the walls even though the columns/beams are behind the walls, when I print it does display correctly but is causing havoc for live detailing. I have been through the basics in VG etc but cannot get it to display correctly.....
I have attached two images to make sure the above makes sense
Thanks in advance for any solutions....
Mon, Dec 12, 2011 at 8:03:24 AM | Linked model overwriting base model display in sections
Can't really see anything because you gave us too larage of a view.
Tell us more.  Is this a linked Revit structural model?
Did you use link by view perhaps in this section view?
Wed, Feb 22, 2012 at 9:41:53 AM | Linked model overwriting base model display in sections
Cotapaxi
Case closed....Structures linked model had CAD imports attached which were over riding our model.
Linked DWG's & Model Display
Wed, Aug 10, 2016 at 6:09:33 PM
Base building model, fitout model and sheets
Wed, Jun 5, 2013 at 5:42:52 PM
Project Base Cannot be Displayed from Linked Model
Mon, Mar 13, 2017 at 3:31:15 PM
Overwrite Linked model - Revit 2014
Sun, Aug 31, 2014 at 10:59:21 AM
Display model
Wed, Dec 16, 2009 at 8:07:34 PM
Page generation time: 0.8960
