Forums >> Workflow & Implementation >> Hardware >> RAC 2012x64 on AMD Radeon HD 6770M - AMD PowerPlay feature vs Revit Hardware Acc
Sat, Dec 10, 2011 at 10:36:22 PM | RAC 2012x64 on AMD Radeon HD 6770M - AMD PowerPlay feature vs Revit Hardware Acc
nematsvehclav
5 Stars: 2 Votes
HP Pavilion dv7-6b76eoi7 2670QM 2.2 GH, 6MB L3 CacheChipset - Intel HM65 Express1TB SATA 5400RPM8GB RAM DDR3 1333MhzSwitchable Graphics between:
The on-board Intel® HD Graphics 3000, which is just for power-saving purposes
and the discrete GPU, which is meant for things like Revit - AMD Radeon HD 6770M 2gb GDDR5
I am running Revit Architecture 2012 x64.
The GPU has a feature called PowerPlay (hereinafter PP). It's a pretty annoying feature as it causes my notebook to experience Black Screen of Death and to freeze now and then while watching movies or while in a video call. So I just disabled the feature and the problems seemed to have gone away until I started up Revit and eventually found out it was unable to utilize Hardware Acceleration, thus it worked crappy. Once I enabled PowerPlay again Revit worked smooth again cos it was obviously taking advantage of Hardware Acceleration (hereinafter HA). Up until that moment I hadn't changed anything in Revit and it was by default having HA turned on. So the possible combinations I got are as follows:
PP enabled + Revit HA enabled = Revit working smoothPP enabled + Revit HA disabled = Revit working smooth (somehow? though disabling HC would make it work bad)
PP disabled + Revit HA enabled = Revit working really bad (???)PP disabled + Revit HA disabled = Revit working smooth (???)
So does this make any sense to anyone? Could anyone explain how enabling and disabling HA affects Revit, because what I expected was that disabling it would make Revit work bad, but apparently it didn't. How is Revit able to work smooth when I turned off HA? I though HA means that the hardware boosts up the performance of the software, What happens in the case when HA is disabled and why does it not have any negative effect in my case?
Sat, Dec 10, 2011 at 10:43:17 PM | RAC 2012x64 on AMD Radeon HD 6770M - AMD PowerPlay feature vs Revit Hardware Acc
nematsvehclav
5 Stars: 2 Votes
Sorry! Shift+Enter apparently didn’t work well.
1TB SATA 5400RPM
I am running Revit Architecture 2012 x64. The GPU has a feature called PowerPlay (hereinafter PP). It's a pretty annoying feature as it causes my notebook to experience Black Screen of Death and to freeze now and then while watching movies or while in a video call. So I just disabled the feature and the problems seemed to have gone away until I started up Revit and eventually found out it was unable to utilize Hardware Acceleration, thus it worked crappy. Once I enabled PowerPlay again Revit worked smooth again cos it was obviously taking advantage of Hardware Acceleration (hereinafter HA). Up until that moment I hadn't changed anything in Revit and it was by default having HA turned on. So the possible combinations I got are as follows:
Sun, Dec 11, 2011 at 8:05:45 AM | RAC 2012x64 on AMD Radeon HD 6770M - AMD PowerPlay feature vs Revit Hardware Acc
coreed
coreed Avatar
4 Stars: 16 Votes
I dont know alot about effects of HA. But Revit should basically run fine if HA is on or off. Depending on your graphics card you should get better performace if HA is on when working in 3d with large models. there are certain Revit features like Photo Realistic display that only work when Ha is on.
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Mon, Dec 12, 2011 at 6:48:31 AM | RAC 2012x64 on AMD Radeon HD 6770M - AMD PowerPlay feature vs Revit Hardware Acc
nematsvehclav
5 Stars: 2 Votes
Thanks! It seems, though, that it works just fine for me even in 3D, even in Realistic type view.
AMD DUAL CORE V INTEL DUAL CORE PROCESSORS [ 1 2 ]
Wed, Jan 25, 2006 at 2:00:11 AM
15
NVIDIA GeForce 5600 128MB DDR VS ATI RADEON 9800 PRO ATLANTIS 128MB DDR
Sat, May 8, 2010 at 6:31:08 PM
Hardware for Revit
Wed, Apr 30, 2008 at 7:31:43 AM
Cache memory Revit 2013
Fri, Sep 14, 2012 at 3:31:15 PM
Curtain Wall Mullion Profile Does Not Display When Cut in a Segmented Section
Fri, Sep 28, 2012 at 11:11:19 AM
Page generation time: 2.3468
