Forums >> Revit Building >> Technical Support >> shading and shadows in 2011
Fri, Dec 9, 2011 at 8:52:08 AM | shading and shadows in 2011
bickel
I'm using Revit 2011 and I've been using Revit since Revit8.
I'm doing exterior elevations and perspectives and I want them shaded w/ shadows.
The problem I'm having is with color consistency.  In Revit 2009 you could go to advanced graphis under the shadow tool and make it consistent by checking a box...I can't remember what the box said.  But what it did, was give me a consistent color whether I used shadows or not.
I don't see anything that will allow me to do this with 2011 and it's driving me nuts.  I know there is the consistent shading, but then you can't use shadows.  And if I use the shading w/ edges it's all washed out so that you have to play with the color and the settings so much that you can't get an elevation and a perspective to look that same.
Am I missing something?  It seems like that shading w/ edges is much less user friendly than it used to be.
Moving shadows in animations
Thu, May 5, 2011 at 5:42:26 PM
SHADOWS ON SITE PLAN ORIENTED TO PROJECT NORTH AND NOT TRUE NORTH
Sun, Mar 9, 2008 at 11:08:24 PM
Revit 2011: Linked model not displaying casting shadows
Tue, Sep 28, 2010 at 1:55:13 PM
revit arch 2011 - elevation and 3d views with shadows!
Fri, Jan 14, 2011 at 8:18:09 AM
Shading Colour
Mon, Feb 15, 2010 at 4:47:51 AM
Page generation time: 2.7127
