Forums >> Revit Building >> Technical Support >> takes too long to save my file!
Thu, Dec 8, 2011 at 2:20:53 PM | takes too long to save my file!
johnsonsara
It is taking 5-8 minutes to save my files that range from 5-15 MB.  I've been working with these files for a while and they used to save quickly (under 30 seconds).  I am working in 2012 and have downloaded service packs 1 and 2 to see if that would help.  It didn't.  I've audited, purged, resaved and renamed.  Worksharing has NOT been enabled. I've been told to reinstall the entire program, but that takes a couple hours.  Is there anything else I can try first?  What is the problem?
Computer specs: intel(R) core TMi7CPU, 2.94 GHz, 12MB ram, 64 bit, nvidia quadro 5500 graphics card. Thanks much!
Thu, Dec 8, 2011 at 3:21:03 PM | takes too long to save my file!
Are you saving with a highly detailed view or tiled views.  If so, Revit has to save all that data.  Save from a very simple legend or detail view.
Wed, Feb 1, 2012 at 10:56:55 AM | takes too long to save my file!
JRPcad
I was having a similar problem and found this thread, I have a 32MB Model and had approximately 20 tiled windows open, the model was taking around 10 minutes to save. just by closing all of the tiled windows and saving in a basic plan it cut the time down to 1.5 minutes, that's a hell of alot of time saving over the working day. thanks Hub Winking
For Architectural Services visit www.jrpcad.co.uk
Revit 9.1 Save to Central Takes 20 Mins
Fri, Sep 7, 2007 at 12:13:46 PM
12
Compact file during Save As
Wed, Feb 16, 2011 at 9:29:18 AM
Extremely long plots
Thu, Jun 22, 2006 at 6:18:38 AM
can't save as a central file
Wed, Sep 9, 2009 at 2:35:47 PM
Help! How to save a template file as an rvt file?
Wed, Aug 20, 2008 at 11:27:01 PM
Page generation time: 1.6304
