Forums >> Revit Building >> Technical Support >> The ability of adding text or symbols into line patterns
Thu, Dec 8, 2011 at 1:59:17 PM | The ability of adding text or symbols into line patterns
ck279
It is somewhat restricting to only have dash, dot or space available when making line types. Sometimes it would be good to be capable of adding text or symbols. ie for a ---gas--- line or fence line with an ---o--- or ---[]---
wouldnt that make life simple? Autocad can do it, Revit is autocad, cant they share?
Thu, Dec 8, 2011 at 3:17:54 PM | The ability of adding text or symbols into line patterns
This has been discussed for years and is on the wish list.  BTW - Searching the forums is always a good idea.
Look at this blog under feb 07 - there is an article on how this can be achieved.
http://revitfamilies.blogspot.com/search?updated-min=2007-01-01T00%3A00%3A00%2B02%3A00&updated-max=2008-01-01T00%3A00%3A00%2B02%3A00&max-results=16
Thu, Dec 8, 2011 at 3:53:27 PM | The ability of adding text or symbols into line patterns
Josie504
You can create at ‘Repeating Detail’, see attached . . .
Wed, Dec 21, 2011 at 4:43:59 PM | The ability of adding text or symbols into line patterns
ck279
Ive read the blog which has got me so far but Im totally lost to be able to create a formula of the number of times the word / symbol appears within a length. I can only seem to get the word / symbol to appear at the fixed locations and but nothing changes if the line gets longer. I need it to add more words/symbols the longer the line gets.
Any hints for a formula for this. I have searched the forums, blogs, and revit help.
Wed, Dec 21, 2011 at 5:55:36 PM | The ability of adding text or symbols into line patterns
rod23
5 Stars: 4 Votes
Here, check this out.  I found this online a while ago and have improved upon it.  The number of text instances is an array with a parameter for number.
http://www.turbosquid.com/Search/Artists/Revitaoist
Sun, Jan 8, 2012 at 12:43:28 PM | The ability of adding text or symbols into line patterns
ck279
Thanks Rod23 thats awesome
Mon, Jan 9, 2012 at 7:50:19 AM | The ability of adding text or symbols into line patterns
Ptrdckrsn
Ptrdckrsn Avatar
1 Stars: 1 Votes
I WATCHED A SCREEN CAST FROM AUOTDESK UNIVERSTIY LAST WEEK. I THINK IT WAS FROM 2010 AU.  thEY DID EXACTLY WHAT YOU WERE WANTING Y USING A GENERIC LINE BASED FAMILY. HE PUT SYMBOLS TEXT. NOT TO HARD TO SET UP. iF YOU HAVE A AU SUBSCRIPTION I WOULD LOOK IT UP. IF THINK IT WAS CALLED TIPS AND TRICKS, AGAIN IT WAS FROM THE 2010 AU. 2011 AU HAS ONE CALLED 45 TIPS IN 45 MIN. IT IS NOT IN THAT ONE.
Thu, Oct 30, 2014 at 2:45:39 AM | The ability of adding text or symbols into line patterns
loganlkemp
This post explains it step by step in a very effective way.
http://www.cadapult.net/aecblog/2011/02/creating-complex-linetypes-in-revit/
However, this method requires you to manually enter the number of times the text appears in the line. I didn't like that so I modified the "Label Instances" Parameter to be Length/666. I also made the "End Gap" 333 so at corners/ends it would appear to be part of one continuous line. Eventually I changed the end gap to 400 so text didn't overlap.
See attached family for 1 and 2 hr fire rating.
Text symbols [ 1 2 ]
Tue, Mar 10, 2015 at 10:14:14 PM
18
Text Symbols? [ 1 2 ]
Tue, Apr 28, 2009 at 2:43:34 PM
22
text symbols
Thu, May 31, 2007 at 3:39:19 PM
symbols in text
Tue, Apr 4, 2006 at 11:52:47 AM
Associating Line styles with patterns
Tue, Sep 18, 2012 at 11:30:05 AM
Page generation time: 1.1447
