Forums >> Revit Systems >> Technical Support >> Wall layer thickness turned "variable"
Thu, Dec 8, 2011 at 10:36:13 AM | Wall layer thickness turned "variable"
romanosyr
anyone have any clue how this could happen?  or how i can fix it (get it back to put in a normal dimension)?
There was a stacked wall using this wall but why would that affect the width?  I also removed the stacked wall and still no change.
Wed, Aug 21, 2013 at 3:25:34 PM | Wall layer thickness turned "variable"
njitrrr
I am sure what you did was split region.  If you merge region on that layer and find where you split it you should be able to bring it back to the proper dimension.
Errors using Membrane Layer: zero / non-zero thickness
Wed, Aug 7, 2013 at 6:08:50 PM
Variable Thickness Wall?
Fri, Feb 10, 2017 at 6:09:58 PM
Roof with variable thickness on sloping framing
Wed, Jan 20, 2010 at 10:12:06 AM
Kenoting a Membrane Layer (0" thickness)
Sat, Feb 12, 2011 at 12:23:27 PM
Zero thickness wall layer
Mon, Mar 30, 2009 at 7:22:16 AM
Page generation time: 2.8751
