Forums >> General Discussion >> Revit Project Management >> Mass in Place Countertop
Wed, Dec 7, 2011 at 6:55:25 PM | Mass in Place Countertop
terryhouse
I had to design a counter top using the model in place command.  How do I change the visibility so the cabinets underneath can be visiable, like the countertop components you can download.
Thu, Dec 8, 2011 at 3:04:19 AM | Mass in Place Countertop
FrankyDHalliday
FrankyDHalliday Avatar
3 Stars: 2 Votes
Select the modelled delight of a cupboard, go on and click it!
and on the top of your screen you will see a visibility tool panel on the von ribbontrop click it and then check the appropriate visibility checkbox = on.
voila
Dr. Zaius: Ah, yes - the young ape with a shovel. I hear you're planning another archeological expedition. Cornelius, a friendly word of warning - as you dig for artifacts, be sure you don't bury your reputation.
Thu, Dec 8, 2011 at 7:01:41 AM | Mass in Place Countertop
You can also use the "show hidden elements" process.  Read this topic in your HELP:> Showing Hidden Element Lines
Sweeping Solid In-Place Mass
Tue, Apr 27, 2010 at 3:30:38 AM
cannot get sink at countertop elevation (revit 2013)
Wed, May 7, 2014 at 12:16:09 PM
Countertop Invisibility
Mon, Jan 5, 2009 at 1:46:39 PM
How do I add a countertop to the Base Cabinet - Corner Unit Angled?
Tue, Mar 28, 2006 at 3:39:10 PM
In-Place Mass Wirefram
Fri, Jan 11, 2013 at 8:47:32 AM
Page generation time: 1.0867
