Forums >> Revit Structure >> Technical Support >> Clevis & cable
Wed, Dec 7, 2011 at 2:44:15 PM | Clevis & cable
cketros
Please help, I start to create clevis+cable and want them to be able to control by dimension and agle, every thing seem ok except the upper clevis won't rotate.
Wed, Dec 7, 2011 at 4:17:04 PM | Clevis & cable
TKennedy
4 Stars: 8 Votes
Try modeling the clevis as a separate family, then nesting and constraining it. That seems to work out the best when you are trying to rotate elements.
Wed, Apr 25, 2012 at 9:23:19 AM | Clevis & cable
pkopf
Here is one that I made.  The key for me to make this work was to have a reference line between the two pin locations and then draw the clevis attached to the reference line.  This one is made for a specific case (1 1/2" diameter rod / 3 1/2 clevis) but could easily be made more parametric.
See if this does what you wanted.
Wed, Apr 25, 2012 at 11:29:35 AM | Clevis & cable
mbsteve
mbsteve Avatar
4 Stars: 13 Votes
I modeled this as a line based object.
CLEVIS & TIE ROD
Wed, Nov 14, 2018 at 10:21:56 AM
nested family rotation
Tue, Sep 3, 2013 at 1:25:41 PM
Clevis and Roller Hangers
Wed, Apr 30, 2014 at 11:54:25 AM
Smart conduit and cable tray hangers
Fri, Feb 7, 2020 at 10:47:56 AM
How to do Cable Tray with Real Material Color (Not just filter color)
Wed, Feb 18, 2015 at 3:14:07 AM
Page generation time: 0.1901
