31 Users Online (29 Members):
Forums >> Revit Structure >> Technical Support >> Level Shared Parameter
Does anybody know if theres a way to make a level shared parameter in plan (see attachment)
I have been using text to call up a beam level in plan. the problem with text is that if the beam changes level the text wont.
just want to know how you guys call up beam levels in plan and also if there is a way of making a level shared parameter in plan ???
regards
Doesn't a spot elevation tag work here? You can create one that doesn't have the target.
I dont know, thats why ive come on here asking how you guys do it. is that the prefered method using a spot elevation without the target ?
If i was to make a spot elevation without the target is there a way to make it Orientate the same way has the beam ? just like a framing tag would ?
regards
MODIFY YOUR STRUCTURAL TAG AND ADD "START LEVEL OFFSET"
but that just gives me the offset of the level, i want the spot elevation call up
regards
Cannot Locate SHARED PARAMETER FILE! |
Tue, Oct 7, 2008 at 3:16:48 PM
Shared Material Between Families |
Mon, Aug 31, 2015 at 11:21:40 AM
Referencing a Shared Parameter in a Family parameter formula. |
Thu, Jan 29, 2015 at 1:26:24 PM
Instance Shared Parameter?? |
Fri, Jul 11, 2014 at 2:49:26 PM
Add Family name to a shared parameter |
Tue, Jun 23, 2015 at 8:50:48 AM
