Forums >> Revit Building >> Technical Support >> set up of 3 point plane
Wed, Dec 7, 2011 at 7:59:43 AM | set up of 3 point plane
paulgrambal
Hello there!
I would like to create the red plane, any ideas?
I made the triangular extrusion and now i need to work on that plane made by 2 base point and one top face point.
thank you!
Wed, Dec 7, 2011 at 8:06:58 AM | set up of 3 point plane
Dafpfy
3.5 Stars: 11 Votes
if you make this as a floor you can set the height of the different corners with 'modify sub elements'
"There is no path to peace,
peace is the path."
Mahatma Gandhi.
Wed, Dec 7, 2011 at 8:20:37 AM | set up of 3 point plane
paulgrambal
hi, this should be a curtain wall panel, I am working in the family editor, so no floors!
I did the model in rhino and now I am using the imported gemetry planes to build the panel, but I think it can be faster to model directly in revit setting the proper plane with 3point, isn't it?
Wed, Dec 7, 2011 at 8:38:23 AM | set up of 3 point plane
Dafpfy
3.5 Stars: 11 Votes
if you can put a reference plane in the correct orientation, you can orient your 3d view to that ref plane, and put an extrusion on it,
peace is the path."
Mahatma Gandhi.
Set roof or soffit on work plane?
Mon, Dec 2, 2013 at 12:57:49 PM
14
Toposurface Elevation Base Point
Thu, Apr 28, 2016 at 4:35:51 PM
cant set work plane
Fri, May 11, 2018 at 1:06:35 AM
Change Angle of referance plane?
Thu, May 3, 2012 at 8:56:49 AM
cavity close/ help
Wed, Sep 17, 2014 at 3:30:19 PM
Page generation time: 0.5896
