Forums >> Revit Building >> Technical Support >> Roof line not showing!
Tue, Dec 6, 2011 at 11:16:23 PM | Roof line not showing!
tmilgate
Hi, I am new to revit & have alot of trouble with my roof lines not showing!
If i modify a roof, once i click finish the roof line disapears from my floor view!
Can anyone please help me get it back?
It does slot, sometimes will delete the whole thing or sometimes just sections of the roof line!
Wed, Dec 7, 2011 at 3:35:14 AM | Roof line not showing!
4 Stars: 205 Votes
Are you in the right Plan View? If you created that roof in Level 2 and you are in Level 1, when you finish the sketch you'll not seen that roof lines unless you change the Underlay of that view.
"It does slot, sometimes will delete the whole thing or sometimes just sections of the roof line!" - Play with "view Range" in that view.
In your HELP menu, search for "Underlay" and "View Range"
Wed, Jul 12, 2017 at 11:58:52 AM | Roof not showing!
valdezz
hello am new to revit. when i use the command roof on my plan it does not appear i can only see the rectangle the roof command created when i used the pick wall command and on 3d it appears as a slab .really need help. thanks in advance
Wed, Jul 12, 2017 at 2:18:06 PM | Roof line not showing!
pijpiwo
pijpiwo Avatar
5 Stars: 25 Votes
Take a look at your Help Menu. It should help you to get started.
Thu, Jul 13, 2017 at 12:48:29 AM | Roof line not showing!
tim123
4 Stars: 19 Votes
It would appear that your roof has been created on the floor level.  Move it to the next level so that it is at the correct height.  Your roof appears as a slab because it has no slope.  Edit the boundary and set the lines for sloped roofs to 'define slope'.  There is a tick box to define the slope when you select one of the boundary lines.
Thu, Jul 13, 2017 at 3:49:49 AM | Roof line not showing!
valdezz
Tim 123, ohhh i see let me try to adjust that.
Thu, Jul 13, 2017 at 4:27:33 AM | Roof line not showing!
valdezz
thanks alot tim123. i figured it. Gracias
Wed, Jul 19, 2017 at 4:43:28 AM | Roof height
valdezz
Hello everyone. my roof slope is 45 degrees but the height is too high so i want the height of the roof to be at 2meters with the slope at 45. thanks in advance
Wed, Jul 19, 2017 at 7:16:01 AM | Roof line not showing!
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
The height of your roof is going to be determined by the pitch and width of the building.  If its to tall you need to reduce the pitch or change the width of your building.
Line Weights not showing in View
Tue, Jul 8, 2014 at 12:45:18 PM
Roof Plan Issues- lower roof showing above upper roof
Thu, Dec 10, 2015 at 3:10:46 PM
Line weights to roof
Mon, Dec 5, 2005 at 8:30:49 PM
Roof not showing all layers of sructure in some sections
Fri, Sep 15, 2017 at 1:25:04 AM
11
Need Help with roof around bay
Fri, Oct 2, 2009 at 1:34:21 PM
Page generation time: 3.0819
