21 Users Online (19 Members):
Forums >> Revit Building >> Technical Support >> window tags
41 Posts No Rating |
I would like to know why I can change the symbol for door tags with no problem and the symbol agrees with the mark in the properties dialog. When I try to change the number or letter in the window tags, I get a message that I am changing a type parameter and it takes a long time for the change to take place. The tag label doesn't agree with the mark label. Help please. Use Revit 2011.
Carl
You can set up any tag to read any family's shared parameters. Those can be type or instance parameters. If you don't want your window tag to read the type parameter, then you should edit that family, creating a new one, that reads the instance mark number.
Window Tags not working |
Fri, Sep 24, 2010 at 7:30:45 PM
window tags in elevation |
Tue, Feb 13, 2007 at 12:51:56 PM
WINDOW TAGS |
Thu, Feb 13, 2020 at 12:20:54 PM
Door and window tags |
Thu, Nov 3, 2011 at 8:51:34 AM
Room Window and Door Tags |
Thu, Nov 15, 2007 at 9:21:10 PM
