Forums >> Community >> Newbies >> aligned acting like linear (up-down, left-right)
Tue, Dec 6, 2011 at 3:24:50 PM | aligned acting like linear (up-down, left-right)
JoBrowns
For some reason, when i use the dimensioning function, I click on "aligned" and it only gives me an "up-down" or "left-right" axis ( when I am looking at the page) to measure from instead of a point (for which I can make angled dimensions). I thought that was only for linear dimensions.Why is my aligned dimensions not working at angles?Many thanks, deeply appreciated.Joseph
Tue, Dec 6, 2011 at 3:35:49 PM | aligned acting like linear (up-down, left-right)
It works for angles.  Are you starting with an elemental line at that angle?  It sounds like you want to do point to point.  To select a point, use your tab key.
Tue, Dec 6, 2011 at 3:48:34 PM | aligned acting like linear (up-down, left-right)
JoBrowns
that's the thing - the tab key is giving me ONLY horizontal and vertical. No points. That's the weird thing.
It's one of those maddingly frustrating things. It just won't become a point so that I can do a point-to-point measurement.
Many thanks
Tue, Dec 6, 2011 at 3:52:48 PM | aligned acting like linear (up-down, left-right)
This is a process problem - not a program malfunction.  For dimensions (not measurements) at an angle, from a point to a point, you have to tab select the point - AT EACH END!  Otherwise, it assumes you mean that line you are pointing at.
When you do select a point, you will see a tiny blue dot.
Tue, Dec 6, 2011 at 4:00:40 PM | aligned acting like linear (up-down, left-right)
JoBrowns
You're absolutelyl right. It was a TINY blue dot - which I missed. That was why. I finally got it to work.
Hopefully this thread will help others with the same mistake.
Many thanks, and deeply appreciated.
JLB
Aligned dimensions on non-orthogonal walls
Sun, Jun 11, 2006 at 8:16:11 PM
Tag dimensions to reference plane in 2010
Wed, Jan 6, 2010 at 10:31:26 AM
Linear lights aren't linear at all?
Fri, Feb 4, 2011 at 1:54:01 PM
Need help dimensioning this wall!
Sat, Jul 25, 2009 at 11:14:13 AM
can't dimension this wall
Sat, Jul 25, 2009 at 11:06:27 AM
Page generation time: 1.0281
