Forums >> Revit Building >> Technical Support >> Noob: can't seem to view level 2 plan view after i changed the wall base offset
Tue, Dec 6, 2011 at 6:14:16 AM | Noob: can't seem to view level 2 plan view after i changed the wall base offset
mikeyos
I can't seem to view level 2 plan view after i changed the wall base offset to -2000 Cryingthe hight of my wall)  ....however i can see level 2 in 3d view attached to level 1 which i want. i just need to see the the plan view of level 2 and attached to level 1 at the same time.
Tue, Dec 6, 2011 at 7:32:16 AM | Noob: can't seem to view level 2 plan view after i changed the wall base offset
mikeyos
i actually figured it out lol...im so stupid ...i didnt change the levels in the elevation view to attach all the walls from each level to the correct hight. anyways ...
Walls show up on Second Level plan
Wed, Dec 19, 2018 at 8:39:24 AM
Wall Base Offset... one works, one doesn't. Why?
Wed, Jun 10, 2015 at 2:53:52 PM
Can't see first storey walls in first storey plan view
Mon, May 5, 2014 at 9:02:22 PM
View Range
Mon, May 17, 2010 at 4:48:55 PM
Imported Component won't show up in plan view.
Thu, Aug 30, 2012 at 12:49:26 PM
Page generation time: 1.8847
