18 Users Online (16 Members):
Forums >> Revit Building >> Technical Support >> Forcing a drafting opening /closing view with Macro
Can revit be forced to open and close to a blank/text drafting view to reduce the time it takes for other revit technicians to open and close files that have been saved on heavy views?
Can revit do this natively, is a macro required to be written?
I appreciate your comments!
Dr. Zaius: Ah, yes - the young ape with a shovel. I hear you're planning another archeological expedition. Cornelius, a friendly word of warning - as you dig for artifacts, be sure you don't bury your reputation. |
Revit always opens the file from how it was last saved. In our projects, we ask our users to save (or save to central) from a designated "PROJECT LEGEND" view that has project information in it... project description - team - important issues... etc. Just switch to a similar small view (not tiled) and save. BTW - This also reduces the overall project file size.
What version of Revit? 2012 now does this automatically. Go to the Manage tab and select Starting View. It defaults to 'last opened', but you can change it to any view in the project. It doesn't matter what view was active when the project was saved/closed, Revit will always open that view.
I create a drafting view in my template called "sync to central" i add some project info a startup instructions in it and set it as the default starting view. I also have people use this view with all others closed to syncronize.
Thanx TK,
I was wondering if there was such a way of overiding the last saved view and open with the same view each time. I shall test it out tommorow at work.
Bi-Fold doors parametrics for opening and closing 3d panels by percentage? |
Wed, May 16, 2012 at 10:14:45 PM
Flagging new Drafting Views - How to reference a drafting view detail? |
Wed, Aug 1, 2007 at 10:26:29 AM
Macro request |
Mon, Jul 19, 2010 at 10:35:00 AM
Closing Down a Project |
Thu, Mar 13, 2008 at 2:51:53 PM
Would like to copy a drafting view from one project to another. [ 1 2 ] |
Mon, Jan 4, 2016 at 6:07:17 PM
17
