Forums >> Revit Structure >> Technical Support >> Material Take Off Schedule
Mon, Dec 5, 2011 at 5:59:09 PM | Material Take Off Schedule
TzH09
Hello,
I'm looking to create a 'Total Steel Mass' schedule for a structure I've created. However it doesn't appear that Material Take Off Schedules incorporate 'Structural Connections' nor 'Structural Stiffeners'.
I generally wouldn't worry if they were tiny 6mm Cap Plates but due to the size of my structure there are some massive End Plates and Stiffeners that add a fair weight to the structure.
I considered using a normal schedule but I'm not able to select the right parameters to complete what I'm trying to do (Volume, Type and a Calculated Value for Mass).
I've thought about creating seperate schedules for Connections, Stiffeners and Framing/Columns but then the total Mass isn't automatically calculated. It would be untidy after all this effort to not have the Total Mass constantly up to date.
Any ideas?
Schedule material mark in door schedule - Revit 2014
Fri, Jan 19, 2018 at 2:57:03 PM
Schedule material mark in schedule type other than material Schedule?
Wed, Jun 22, 2011 at 3:59:07 PM
Material schedule not picking up materials in railing object
Fri, May 6, 2011 at 4:03:35 PM
material tag schedule problem
Sat, Mar 25, 2017 at 7:50:36 AM
Differences between Schedule and Material Takeoff Schedule?
Thu, Feb 9, 2012 at 7:31:53 AM
Page generation time: 1.1999
