Forums >> Revit Building >> Technical Support >> making a ramp
Mon, Dec 5, 2011 at 3:26:47 PM | making a ramp
joewallace
i want to make a large ramp and its in a U shape, although more rounded at the top and i want to top piece,where it curves to be the heighest point and then sloping down to the ends. has anyone any idea how to do this, iv tried using the ramp tool but cant figure it out.
thanks
Mon, Dec 5, 2011 at 3:33:04 PM | making a ramp
Not sure what you want since you were not clear.  We usually do our parking garage ramps using floors.  I would do a U in three sections.
The bottom of the U does not usually slope on ramps like this because the travel distance is not the same on each side.   Sort of why code people don't like winders on stair landings.  The inside slope is too steep.
Mon, Dec 5, 2011 at 3:40:02 PM | making a ramp
joewallace
il try explain myself a bit better. im designing a display area for large sculptures and i want a ramp that will rise up to about 4M at the tip, its a 'U' shape. i want a constant rise from ground level up to about 4M, im just wondering how would i make this in revit
Mon, Dec 5, 2011 at 3:51:30 PM | making a ramp
You say constant rise but that is the problem with a U.  There can not be any constant rise.  The bottom of the U has to twist so you cant do this with flat slabs, normal ramps or sweeps. Good Luck
Tue, Dec 6, 2011 at 11:40:00 AM | making a ramp
mbsteve
mbsteve Avatar
4 Stars: 13 Votes
Try the attached PDF technique for creating street work
car ramps - visual dilemma....
Thu, Aug 10, 2006 at 8:16:06 AM
A ramp!
Thu, Jan 21, 2016 at 11:37:45 AM
Walls on Ramp
Fri, Feb 15, 2013 at 11:22:57 AM
RAMP TAG FAMILY FOR RAMP NAME
Mon, May 9, 2016 at 6:49:09 AM
Ramp Slopes
Thu, Jun 4, 2015 at 3:19:33 PM
Page generation time: 3.9411
