Forums >> General Discussion >> Revit Project Management >> Mid-project Program Update (Revit 2011 to 2012) HELP PLEASE!
Mon, Dec 5, 2011 at 9:59:10 AM | Mid-project Program Update (Revit 2011 to 2012) HELP PLEASE!
kcaparella
Hi all! We just received updated models from the architect and the files are now 2012 Revit. Up until now everything we had received had been 2011, so that was the version I was working with (we have 2012 also). I guess my question is, what is the best way to upgrade my central file from 2011 to 2012 w/o any information loss so that I can apply the new architectural updates? Will I even be able to update the linked files to the new files if the file names don't match exactly (ie. old files "A_N_Exterior_13317_2011_Central" & new files "A_N_Exterior_13317_2012_Central")? Thanks for taking the time to read my post! Any help with this is greatly appreciated! Sincerely, Kcaparella
Mon, Dec 5, 2011 at 10:06:50 AM | Mid-project Program Update (Revit 2011 to 2012) HELP PLEASE!
Upgrading a project should be a consentual event. All parties need to know about it and what problems may occur by doing this.
To upgrade, simply open the file in the new version and create a new central / local.
Will you have errors?  - Nobody can answer this.  Most likely, there will not be any problems unless you have done some strange things.  But, You need to check it out thoroughly.
Linked files are not problems but each linked file should be upgraded before upgrading the host file.  Path does not matter - use the reload from.
Mon, Dec 5, 2011 at 10:15:56 AM | Mid-project Program Update (Revit 2011 to 2012) HELP PLEASE!
kcaparella
Working great - no errors so far. Thanks WWHub!
Mon, Dec 5, 2011 at 10:20:36 AM | Mid-project Program Update (Revit 2011 to 2012) HELP PLEASE!
rod23
5 Stars: 4 Votes
There are known issues and errors from upgrading projects in mid development, be sure to archive a 2011 version BEFORE you upgrade.
http://www.turbosquid.com/Search/Artists/Revitaoist
Mon, Dec 5, 2011 at 10:51:32 AM | Mid-project Program Update (Revit 2011 to 2012) HELP PLEASE!
kcaparella
Thanks for the heads up rod23!What sort of errors should I be expecting or have other people experienced?It was not my decision to upgrade program versions mid-project, but it has been done and I am now stuck with making it work. :/
Again, any help is greatly appreciated!
Sincerely,
Kcaparella
Mon, Dec 5, 2011 at 6:57:59 PM | Mid-project Program Update (Revit 2011 to 2012) HELP PLEASE!
rod23
5 Stars: 4 Votes
I've had problems with the material manager after upgrades.  The material manager was revamped for 2012.  Generally, I do not upgrade projects half way through, and ALWAYS archive a copy before upgrading.  Maybe one of your backups is still 2011?  It probably will not give you problems, but it is a pain when things malfunction and no one knows the answer.
Wed, Dec 7, 2011 at 8:54:53 AM | Mid-project Program Update (Revit 2011 to 2012) HELP PLEASE!
kcaparella
Thanks again rod23 for your response.
Seeing as we are working with linked models to create our MEP model and are really only creating basic low voltage wiring plans for the builidings security system I do not believe that, even if there are problems, material management will be of any concern.
I will be certain to archive the old project files before upgrading tho as this sounds like an extremely logical idea. Our backups are 2011, yes, and our firm's central file is also in 2011 - but the other consultants on the project have all converted their files over to 2012 and now I can not update the linked files in our model w/o updgrading the entire project to 2012 version of Revit MEP.
Fingers crossed that I don't run into any unforseen issues!Thanks again!Kcaparella
How to have Revit files open in 2011 instead of 2012
Tue, Jul 19, 2011 at 10:02:45 AM
2012 to 2011
Tue, Nov 15, 2011 at 6:12:46 PM
Revit drops licence mid-sessions (2009-2011)
Fri, Dec 10, 2010 at 11:02:33 AM
Where have my templates gone in 2012
Sat, Apr 7, 2012 at 9:09:06 AM
"auto" open in Revit 2012, when you have both 2012 and 2013
Sun, Jul 12, 2015 at 4:52:17 PM
Page generation time: 1.8041
