Forums >> Community >> Newbies >> How to render with night mode on revit architecture 2011
Sun, Dec 4, 2011 at 9:16:08 AM | How to render with night mode on revit architecture 2011
eniak
5 Stars: 5 Votes
Please i need help on rendering night mode none none of the light will emit while rendering both interior and exterior have done all i could yet nothing seems to work after rendering it only produce this black image which i attached below i really need help please any one there to help thanks
Sun, Dec 4, 2011 at 10:56:33 AM | How to render with night mode on revit architecture 2011
coreed
coreed Avatar
4 Stars: 16 Votes
here's some info;
http://www.revitcity.com/forums.php?action=viewthread&thread_id=24279
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Sun, Dec 4, 2011 at 12:24:02 PM | How to render with night mode on revit architecture 2011
Audiophyle
If the above doesnt do anything, take a closer look at your lights.  I had a very similar problem on a project last semester that no matter what I did the lights were non-existant.
Didnt figure it out until a few months ago, but my issue was the roof & ceiling were too close together. My recessed lights were cutting away the ceiling no problem, but the lights were getting embedded into the roof (or floors above) structure so no light was getting out.
I went into the structure details of the roof & removed the structural layer, so it was basically a thin piece of insulation & roofing material. Then I went into the ceiling details & added the structure for the roof.  Essentially the section drawing reads exactly the same, however getting the structure portion into the ceiling instead finally allowed the lights to cut away as needed, and the renderings came out significantly better (albeit 6 months too late).
Sun, Dec 4, 2011 at 12:55:07 PM | How to render with night mode on revit architecture 2011
eniak
5 Stars: 5 Votes
well i just try those adjustment and yet nothing and any interior rendering both night mode and daylight mode nothing seems to work all just come out dark as it is
Sun, Dec 4, 2011 at 2:16:06 PM | How to render with night mode on revit architecture 2011
eniak
5 Stars: 5 Votes
i just reduce my ceilling height from 2.6m to 2.4m and also hide the cielling on the render view so this is what i got
Sun, Dec 4, 2011 at 2:26:38 PM | How to render with night mode on revit architecture 2011
Audiophyle
Its not the ceiling, its the roof/floor directly above the ceiling that Im talking about.
What lights are you using? Stock ones bundled with Revit or custom downloaded ones?
Sun, Dec 4, 2011 at 2:55:02 PM | How to render with night mode on revit architecture 2011
eniak
5 Stars: 5 Votes
ok what will i do to the floor then.... the picture below show my kind of light, but one thing is when i turn on the light source on from the visibility graphic it show the light source but rendering nothing show
Sun, Dec 4, 2011 at 11:16:06 PM | How to render with night mode on revit architecture 2011
Audiophyle
I am 100% positive this is your problem, which is what I am talking about.
http://therevitkid.blogspot.com/2010/01/tutorial-floor-or-ceiling-what-to-do.html
There is even a walkthrough video explaining exactly what the issue is and how to fix it.
(I hope posting this link isnt against the rules)
FYI that is WAY too many lights for that space, do you happen to work for the electric company? (just teasin)
Edited on: Sun, Dec 4, 2011 at 11:17:55 PM
Mon, Dec 5, 2011 at 3:42:41 PM | How to render with night mode on revit architecture 2011
eniak
5 Stars: 5 Votes
hey hey audio your suggestion work completely for me thank you so much
Revit to 3ds night render
Thu, Jul 30, 2009 at 1:26:02 PM
Can I render in Family mode?
Mon, Mar 29, 2010 at 6:37:04 AM
night rendering in 2012
Mon, Apr 23, 2012 at 2:56:19 PM
I"M HAVING DIFFICULTY CHANGING THE RENDER COLOUR OF MY BALUSTER/STAIRCASE
Wed, Jan 19, 2011 at 4:52:18 PM
14
REVIT ARCH 2011 render problems
Fri, Sep 16, 2011 at 2:04:13 PM
Page generation time: 3.0507
