Forums >> Community >> Newbies >> Copy Monitor
Sun, Dec 4, 2011 at 4:31:02 AM | Copy Monitor
FrankyDHalliday
FrankyDHalliday Avatar
3 Stars: 2 Votes
RAC2012
We are going to be combining structural elements into our main architectural models.
There are many pros and cons,
Cons
  • We are going to lose dimensions as we use the structural elements in place of the architectural elements?
  • We can't use our floor hosted families that are already in place. We will have to use surface hosted elements, perhaps this involves revising all our families that are floor hosted.
  • We will lose opening , cut or void families in the floor slab
  • There is a great amount of work in removing arch elements deprecated or removed altogether from the file.
  • join geometry will be difficult to use.
Pros
  • We are going to reduce the number of changes in half as there will be 1/2 the steps involved in editing.
  • We will know instantaneously(as quick as a derivative), what the engineers are getting us into.
  • complexity is reduced and hence mental, psychological strain.
Can this list be supplemented? If so add your comments as to the pitafalls of this operation.
Winking
Dr. Zaius: Ah, yes - the young ape with a shovel. I hear you're planning another archeological expedition. Cornelius, a friendly word of warning - as you dig for artifacts, be sure you don't bury your reputation.
Copy/Monitor walls
Tue, Apr 2, 2013 at 10:14:23 AM
Copy Original Type Not Available in Copy Monitor Options Dialogue
Fri, Nov 6, 2015 at 2:16:27 PM
Can't Get Copy Monitor to Work for Grids and Levels
Fri, Feb 21, 2014 at 4:55:28 PM
Copy/Monitor Lights to Revit Architecture 2012
Wed, Oct 17, 2012 at 3:05:52 PM
Rev Arch 2009 conultants elelments in copy monitor
Wed, Aug 31, 2011 at 2:21:36 PM
Page generation time: 0.2676
