Forums >> Revit Building >> Technical Support >> Modelling stairs and balustrades by level.
Sat, Dec 3, 2011 at 11:37:56 PM | Modelling stairs and balustrades by level.
FrankyDHalliday
FrankyDHalliday Avatar
3 Stars: 2 Votes
First post
When a model is split into files by level and the stairs are modelled in each file, floor to ceiling for that level only, how can the balustrades most efficiently be modelled at each level, should the balustrades be broken at each flight, or at each scissor stair and should the balustrades be segmented centred on goings of a stair run/flight where a baluster needs to be seen.
To control balusters precisely or do the balustrades require breaking at these points.
Franky "D" Halliday
Edited on: Sun, Dec 4, 2011 at 5:39:29 AM
Dr. Zaius: Ah, yes - the young ape with a shovel. I hear you're planning another archeological expedition. Cornelius, a friendly word of warning - as you dig for artifacts, be sure you don't bury your reputation.
Sun, Dec 4, 2011 at 4:49:39 AM | Modelling stairs and balustrades by level.
FrankyDHalliday
3 Stars: 2 Votes
BTW,
How can you align the breaks in the balustrading sketches. In plan these appear to work nicely, however they don't align after getting out of sketch mode. The sketch line appears neither centred, left or right justified.
Sun, Dec 4, 2011 at 8:22:56 AM | Modelling stairs and balustrades by level.
DON'T DO SEPERATE FILES!!
Tue, Dec 6, 2011 at 4:01:15 AM | Modelling stairs and balustrades by level.
FrankyDHalliday
3 Stars: 2 Votes
Can you be specific why we shouldn't separate into files level by level? What pitfalls do you predict WWWhub?
Tue, Dec 6, 2011 at 10:57:49 AM | Modelling stairs and balustrades by level.
alabaster2513
alabaster2513 Avatar
3.5 Stars: 25 Votes
that sounds like some architectural desktop workflow. never heard of anyone doing that in revit. if you are worried about model size autodesk has published a white paper about model management.
Thu, Dec 8, 2011 at 2:44:27 AM | Modelling stairs and balustrades by level.
FrankyDHalliday
3 Stars: 2 Votes
Where can I find this edict from Autodesk?  DOES IT SCALE? You know we are creating a pretty f!@#$n huge model. it's 10 levels at 150-250 x 100-150 m floor plates approx. Further the model is full of fit-out. Yet I am wondering... maybe cris price knows?
Glass balustrades on stairs
Fri, Sep 7, 2007 at 3:07:11 AM
When to model stairs by level or as a vertical model?
Sun, Feb 19, 2012 at 2:03:43 AM
stairs! stairs! STAIRS! help!
Fri, Mar 20, 2009 at 4:34:04 PM
stairs not connecting to landing- see attachment please!
Mon, Mar 5, 2012 at 12:29:45 PM
cut symbol on stairs
Sun, Dec 4, 2011 at 8:21:55 AM
Page generation time: 1.1971
