Forums >> Revit Structure >> Technical Support >> Navisworks Appended Files
Fri, Dec 2, 2011 at 1:46:33 PM | Navisworks Appended Files
nambrosino
This seems like such a simple problem, but I have not been able to figure it out or find anyone that knows....
I have created a Navisworks file with multiple appended cache files which were created in Revit.  All I want to do is remove one of the cache files I added to the master nwd file.  When I click on it in the selection tree there is no option for delete and I cant find anywhere else to remove it.
I'm sure its probably something simple, but the simple ones are the most frustrating!
Thanks in advance!
-N
Tue, Dec 13, 2011 at 4:43:28 PM | Navisworks Appended Files
Eddieboarder91
Eddieboarder91 Avatar
4 Stars: 8 Votes
once you create an nwd you are not able to remove any of the sub files, just hide it and append the update.
www.allbimallthetime.blogspot.com
http://familyjewels.typepad.com/
2016 export Revit files to Navisworks without using Navisworks Exporter.
Thu, Apr 21, 2016 at 4:53:15 PM
Navisworks 2016 Linked files not included when exporting to NWC file format
Wed, Apr 20, 2016 at 11:07:17 AM
Revit 2010 and Navisworks 2010
Mon, Mar 1, 2010 at 8:15:35 AM
NavisWorks Exporter
Mon, Mar 28, 2011 at 3:40:00 PM
Casper the Friendly Ghost Add-in NavisWorks 2016
Mon, Apr 25, 2016 at 5:01:17 PM
Page generation time: 0.2661
