Forums >> Revit Building >> Technical Support >> Floorqwall cutting lines - heavy lines at core
Thu, Dec 8, 2005 at 2:37:52 AM | Floorqwall cutting lines - heavy lines at core
Molonesh
I would like the heavy line of a wall or floor to go along the core outline only, and not along other materials (finish, etc.), so for example if i have a floor of 4' concrete, 3' space and 1' flooring, the cut line will show only around the concrete area. Thanks for any help
Thu, Dec 8, 2005 at 4:13:35 PM | RE: Floorqwall cutting lines - heavy lines at core
crispin
Discussed a couple of days earlier - Mr Spot posted solution using overrides http://www.revitcity.com/forums.php?action=viewthread&thread_id=2541 Over rides are a workaround however, and should really not be necessary if through object styles you could define the line weight of layer types of walls/roofs etc This is a problem of revit - control and access to dimensional information of each of the individual layers of walls and floors is not yet good enough. There is fantastic potential here to automate the interaction of host based objects (sweeps, windows etc) once access to wall /floor/ceiling layer host information is available to families to interact with. C
Hid Lines deplicting finishes on walls in plan view to see the core lines only
Sat, May 15, 2010 at 5:49:20 AM
My bump lines are too thick and heavy. [ 1 2 ]
Thu, Aug 11, 2016 at 2:45:38 PM
21
Lines too heavy in perspective view
Wed, May 1, 2013 at 6:36:38 PM
Lines in the middle of beams
Thu, Feb 2, 2006 at 9:09:20 PM
hiding core elements in a wall section
Fri, Jun 23, 2006 at 1:07:58 PM
Page generation time: 1.2116
