Forums >> Revit Building >> Technical Support >> view range in RCP
Wed, Apr 28, 2004 at 1:53:29 PM | view range in RCP
mhudson
I have a corridor with 8'6"' ceilings and 8' high bulkheads running across the corridor, next to the corridor I have a room with 10' ceilings and windows with a head height of 9'0".......How do you get the view range to function? If you put it above the window you can't see the corridor ceilings, if you put it lower than the corridor bulkheads it cuts thru the window and the sill appears along with no header above the window. The sill than cuts off the ceiling grid and it looks like the sill is the boundary for the ceiling.
Wed, Apr 28, 2004 at 3:53:15 PM | RE: view range in RCP
skisouth
5 Stars: 3 Votes
Be sure your sill is a different object style. Turn that object style (sill) off in the RCP.
Thu, Apr 29, 2004 at 8:11:22 AM | RE: view range in RCP
mhudson
thanks
view range wont adjust in RCP
Wed, Jan 31, 2018 at 3:44:20 PM
Ceiling RCP view range
Tue, Jul 29, 2014 at 3:50:24 PM
View Range/Plan Region Visibility Controls in RCP
Wed, Feb 1, 2012 at 11:20:32 AM
see RCP on plan view
Mon, May 17, 2010 at 4:50:56 PM
Unable to place lighting on RCP
Thu, Dec 16, 2010 at 1:39:42 PM
Page generation time: 0.6399
