Forums >> Revit Structure >> Technical Support >> Editing Stairs
Thu, Dec 1, 2011 at 3:34:55 PM | Editing Stairs
gdfisher
I'm working on a curved stairway that has a couple of landings with the top being a balcony in a residence. I have edited the default stair to create a new one by adding different balusters and newels.
What I can't figure out is how to change the top rail (identified in the "Edit Type" window as "Rail 1" with no other selection available). The rail I want to use is shown in the "Load Family/Profiles/Stairs"" dialog and represented only by a 2D profile named "Handrail 2 5/8 x 2 3/8", but I can't understand how to employ it to replace the circular default rail. I've tried using it for a Sweep, but because of the curve and twist in the rail, it can't alogn properly. I' lost.
Second challengs is to alter four of the tapered beginning treads to have arched ends in plan view. Revit doesn't seem to provide a means of changing the plan view profile of individual treads. Any ideas?
Editing the profile of a railing
Fri, Jun 3, 2005 at 11:26:25 PM
Attaching walls to stairs
Tue, Aug 22, 2017 at 12:20:10 AM
13
Wrapping stairs
Thu, Aug 12, 2010 at 5:27:02 PM
Handrails at Curved Stairs
Mon, Sep 1, 2008 at 1:43:04 PM
stairs not dotted above
Fri, Feb 17, 2012 at 1:44:46 PM
Page generation time: 1.6363
