Forums >> Revit Building >> Technical Support >> Can Floor Slab Edge Material be different?
Thu, Dec 1, 2011 at 3:32:45 PM | Can Floor Slab Edge Material be different?
AlphaOjo
Is it possible to change the material at the edge of a floor slab so that it is different from the material on the top?  Ideally I would like to have the top surface of the floor appear as one material, the cut surface as another, and the uncut "side" surface be a third...Is this possible without creating a thin veneer over the edge of the floor?
Thu, Dec 1, 2011 at 3:44:57 PM | Can Floor Slab Edge Material be different?
Use your paint tool.
floor slab edge
Fri, Aug 22, 2008 at 3:31:34 AM
Floor slab edge not joining right REV2008
Tue, Aug 14, 2007 at 3:37:07 AM
adding radius edge to floor slab
Wed, Jul 21, 2010 at 7:47:29 AM
Creating slab edge...
Tue, Nov 4, 2008 at 3:36:02 PM
Composite floor edge
Mon, Oct 1, 2007 at 8:38:41 AM
Page generation time: 6.8529
