Forums >> Revit Building >> Technical Support >> Rotating a fill pattern
Thu, Dec 1, 2011 at 2:44:45 PM | Rotating a fill pattern
Ptrdckrsn
Ptrdckrsn Avatar
1 Stars: 1 Votes
I am detailing a cabinet and my plywood pattern is running horizi, need to run vertical with my region.   what am i missing?
thanks
in advance
Thu, Dec 1, 2011 at 2:58:28 PM | Rotating a fill pattern
You either need a drafting pattern that works verically or use a model fill pattern.  Model patterns rotate.  Search the forums for plywood and you will find a model fill pattern.
Rotating Fill Patterns
Mon, Jan 28, 2013 at 8:34:03 AM
color scheme/fill pattern
Mon, Jul 9, 2012 at 4:56:36 AM
Scaling fill pattern
Thu, Nov 17, 2011 at 4:01:24 PM
Solid Drafting fill pattern
Tue, Jun 23, 2015 at 1:35:01 PM
Rotating a Pattern File
Thu, Jun 18, 2009 at 12:13:16 AM
Page generation time: 0.8793
