Forums >> Revit Building >> Tips & Tricks >> Door hardware Schedule
Thu, Dec 1, 2011 at 1:04:15 PM | Door hardware Schedule
tmassey
tmassey Avatar
I am editing a standard revit door family by adding door hardware such as closers, weather stripping etc. This I have done successfully and it shows on my plan when I load into project. I want these items to show within my door hardware schedule but am not able to do so. I can see my doors and the family information..room, width etc..
I have created a door schedule and added new parameters for harware columns as per...closers, weather stripping etc.
I couldn't find this in the forum. Any help would be appreciated.
cheers
Using Revit Architecture 2012
Thu, Dec 1, 2011 at 1:07:43 PM | Door hardware Schedule
tmassey
tmassey Avatar
I figured it out. cheers
Thu, Dec 1, 2011 at 1:41:40 PM | Door hardware Schedule
We ask users that answer their own questions to contribute to the site by posting their solution.  Please do that so others may benefit.
Fri, Dec 2, 2011 at 11:01:22 AM | Door hardware Schedule
tmassey
tmassey Avatar
I edited the shared parameters to create manual operated fields (yn) txt within our schedule.
1.    Click Settings menu Project Parameters.
2.    In the Project Parameters dialog, click Add.
3.    In the Parameter Properties dialog, select Shared parameter.
4.    Click Select and choose the appropriate shared parameter from the appropriate parameter group.
5.    If desired, click Edit; this returns you to the Edit Shared Parameters dialog, where you can open a different shared parameter file or add new parameters.
6.    Choose whether to store the parameter by instance or type.
For more information on instance and type properties, see Instance Properties and Type Properties.
7.    Under Group, select the heading under which the parameter should display in the Element Properties dialog.
8.    Select the categories to which you want to apply this parameter.
9.    Click OK.
Door Hardware
Thu, Nov 23, 2017 at 11:05:24 AM
Door schedule
Sat, Nov 8, 2014 at 7:47:17 AM
copy/create a new door hardware schedule?
Fri, Mar 27, 2009 at 8:02:13 AM
Door Hardware
Wed, Nov 16, 2011 at 7:27:32 AM
Door Hardware Schedule - nested family
Wed, Jun 20, 2007 at 5:16:23 PM
Page generation time: 0.2544
