Forums >> Revit Building >> Technical Support >> Revit views to DWF format to print
Wed, Dec 7, 2005 at 11:46:17 PM | Revit views to DWF format to print
jyothi
How do we create a Dwf file from revit, there is an option export dwf but only 3d dwf is activated ,the other option 2D dwf is greyed off. i need to create DWF in order to print them in black and white and to display them on the web. Can any one help me regarding this
Wed, Dec 7, 2005 at 11:55:52 PM | RE: Revit views to DWF format to print
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Use the printer Autodesk Revit DWF Writer... works similar to PDF.
Sat, Mar 21, 2009 at 2:41:54 PM | Revit views to DWF format to print
fixybopixy
can u tell me the differences between all the different exporting and printing options? i understand for example, that PNG, TIFF, TGA, and JPG rasterize the revit drawing and make it lower resolution. yet, what about the differences between DXF, DWG, and DWF? what r the differences there? are they all autocad drawings? and what about PDF? which one is the best one to print to for editing in photoshop without losing resolution.
 I.e., should u print a drawing from revit to PDF and then insert the PDF in photoshop? would u export a 3D rendering in Revit as a TIFF for and export a 2D plan or section (as hidden line, not as as rendering) as a PDF?
Sun, Mar 22, 2009 at 9:54:00 AM | Revit views to DWF format to print
You are confusing image files with data files.
DXF - drawing exchange format - used across drawing platforms
DWG - autocad drawing file
DWF - A 3D or 2D or both, image file program from autodesk
PDF - A 2D or sometimes now a 3D image file from adobe
TIFF, TGA, JPG, PNG are all image file standards which are supported by many programs.
Depending on resolutions wanted and file sizes, I would use TIFF or JPG's for files I want to manipulate in photoshop.
Tue, Apr 28, 2009 at 9:04:59 AM | Revit views to DWF format to print
Runyank
Where does one get this Autodesk DWF writer?  Whenever I go to print to DWF it gives me the printer name "Revit DWF exporter"?  Our lineweights are comming out fine when printed directly to the KIP plotter, but when printing to DWF our lineweights are comming in very light, almost half tone.  Please help!
Fri, Mar 19, 2010 at 9:43:13 AM | Revit views to DWF format to print
GSP2
Is this (converting the Revit files to DWF format) the best way to print and view Revit files without actually having the actual Revit application?
Fri, Mar 19, 2010 at 12:21:41 PM | GSP2
coreed
coreed Avatar
4 Stars: 16 Votes
Quoting GSP2 from 2010-03-19 09:43:13
"Is this (converting the Revit files to DWF format) the best way to print and view Revit files without actually having the actual Revit application?"
according to Autodesk it is.
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
DWF Printing
Fri, May 28, 2010 at 8:52:11 AM
DWF and DWFx
Thu, Apr 11, 2019 at 7:29:36 AM
DWF
Tue, Mar 27, 2007 at 10:19:52 AM
How to print sheets bigger than A0 as .dwf?
Fri, Jul 7, 2006 at 6:48:15 AM
Revit 2012 - export DWF - corrupt dwf file
Fri, Aug 3, 2012 at 10:47:11 AM
Page generation time: 3.3336
