Forums >> Revit Structure >> Technical Support >> RAM Model to Revit Structure 2012
Wed, Nov 30, 2011 at 5:47:10 PM | RAM Model to Revit Structure 2012
GEFlem
So I want to import a model from RAM into Revit. I have followed all of the instructions available to me from Bentley, and downloaded the RAM-Revit Link. I'm able to export from Revit into Ram. However, while working in Revit if I click Add-ins-External Tools-Import Model From RAM. I immediately receive an error message which reads "Cannot read mapping file" It goes on to list the file path and states that access to it denied. My mapping file does exist and it is not read-only. If I click OK, the Bentley File Importer Appears, however I'm not able to click on Import after selecting a RAM File Location. If you are successfully transitioning between RAM and Revit I would appreciate some tips...
Thu, Dec 1, 2011 at 5:37:09 AM | RAM Model to Revit Structure 2012
4 Stars: 205 Votes
I don't work with struct. but look at the bottom of this page, you'll see similar threads.
Ram Structure imports
Thu, May 31, 2007 at 1:17:14 PM
Problems with the Revit Structure Analytical Model
Fri, Apr 20, 2012 at 2:43:36 PM
Ram into Revit Structure
Wed, Nov 9, 2011 at 11:12:56 AM
Can Ram steel model be used in revit structure
Tue, Dec 19, 2006 at 6:38:05 AM
RAM and revit 2012
Fri, Sep 23, 2011 at 4:35:54 PM
Page generation time: 1.9794
