Forums >> Community >> Newbies >> Generic Annotation symbol
Wed, Nov 30, 2011 at 1:33:02 AM | Generic Annotation symbol
Vpokunoff
Hey,
I made an annotation symbol for my casework family. I made it little bit bigger than it should be. I guess that generic annotation template has no scale. So how can I make my symbol smaller without doing it manually?
Wed, Nov 30, 2011 at 7:37:28 AM | Generic Annotation symbol
AbsoluteBIM
AbsoluteBIM Avatar
4 Stars: 4 Votes
your generic annotation does have a scale... 1:1. You create the symbol based on how you want it represented when you print it out no matter what scale your drawing view is. You'll have to edit your family manually to reduce the size. You could try to create the symbol in a few various sizes and then set up visibility parameters for each one. This will allow you some flexibility once in the project.
Mon, Dec 5, 2011 at 4:02:48 PM | Generic Annotation symbol
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
You can add a parameter inside the annotation family and tie it to a dimension that drives the 2d geometry.
The parameter can be Instance or Type specific.
A grid bubble with a variable radius is a basic example.
Generic annotation symbol not visible
Thu, Nov 20, 2014 at 10:08:45 AM
Nest Generic Annotation in Detail Component
Wed, Mar 17, 2010 at 7:18:22 PM
Generic Annotation Visibility In RCP
Mon, Oct 9, 2006 at 5:56:39 PM
sloped annotation symbol text
Mon, Aug 15, 2011 at 8:04:20 PM
Annotation Symbol
Wed, Jan 23, 2008 at 6:36:59 AM
Page generation time: 1.0738
